- Dec 6, 2009
- maplevalley WA
- Automatic
I`m pretty sure it has hydraulic lifters you want the cylinder your adjusting on the compression stroke. back out the adjusters on the rocker until you feel lash then tighten it down slowly for zero clearance then another 1 1/2 turns down. Now would be the time to adjust both sides just stick your finger in the plug hole of the cylinder your adjusting and turn it over slow until you feel compression and adjust those two valves. If you havent put the manifold back on yet goop the valleys where the head meet the block with permatex #2 or RTV black to avoid future oil leaks.
