swynx
For awhile now I've been trying to fix a high idle problem on my 94 4.0 5speed When I got the truck it ran poor. I put a new fuel pump in it and a new fuel pressure regulator. That fixed the problem with it not starting under a 1/4 tank. And dieing after high rpm runs. Gained alot of performance back.
I've replaced both 02, the iac, Tps, and the other usual that are described in each of these threads.
I notice these 3 things. On start up it'll idle under a grand like 900ish. If I hit the gas it won't ever idle under a grand, like 12-1300ish. Pushing the clutch in repeatadly will lower the rpms. Above 3 grand it makes a sound like a Turbo car. I wanna say that's normal egr stuff, but Idk.
Hopefully those are good clues.
