Jason
- Aug 23, 2007
- Age
- 46
- (formerly) 200
- Automatic
That wouldn't surprise me so much when in combat. They probably had little time for cleaning, if any time at all. Just think of all the dirt, mud, and crud that those guns got covered in... Not to mention the hundreds, if not thousands of rounds, fired between cleanings... Ammunition was corrosive back then, and required the weapons to be cleaned frequently to prevent corrosion. When you get a buildup of powder residue and fouling, combined with corrosion blocking the gas port in the barrel or gumming up the gas cylinder...it most likely going to jam, because that affects the gas flow that is required to unlock and opperate the bolt.
The normal shooter, even if they hardly ever clean the rifle, will rarely experience any sort of jam. Shooting corrosive ammo, or being in combat, can change that pretty quickly.
true, but the sks/ak's didn't have that problem. and still don't/
