- May 16, 2019
- Los Angeles, CA
- 4.0 V6
- Manual
- Tire Size
- 235/75-R15
Found this on Pick Your Part at the Sun Valley, CA location. The owner must've had a bad day...
Welcome Visitor! Please take a few seconds and Register
for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
I've had several "shootin cars" over the years...
Probably had a 3.0 and the guy had a steep driveway.Found this on Pick Your Part at the Sun Valley, CA location. The owner must've had a bad day...
Wait.... Is this your "shootin car"?
If it has a 2.9 the driver probably couldn’t tell. Is that tapping a little louder today?
Bullet cant catch a 2.9.If it has a 2.9 the driver probably couldn’t tell. Is that tapping a little louder today?
Looks purdy! Are you going to add some sort of lubrication system for the valve train to make up for the one those “German Engineers” forgot?Son.
Just for that, I'm going to chain on to a running 3.0 and rip the crank straight out of the mains.
Already was running a melling 328 high volume oil pump, and have an electric scavenge pump on hand to go between the return side of the turbo and oil cooler. Pump sits at lowest point of oil system, and I have the wiring done to the megasquirt to run it before the engine cranks. So in KOEO, you'll be able to prime the oil system every time the engine is started.Looks purdy! Are you going to add some sort of lubrication system for the valve train to make up for the one those “German Engineers” forgot?![]()
