Some Wheeling Pics
You have one of my favorite rangers on the site, i always look forward to new pics.
Quick question, did you manage to get those wheels balanced? i have the same ones and im told weights cant be put on the outside so i got the steering wheel shimmy.
Thanks man, I'll whore pics any chance I get :derisive: :D
On the wheels, yup, I balance them myself at work. On the inside, I use regular clip-on weights for steel wheels. On the outside, I just use tape truck weights right behind the fake beadlock ring on the flat part of the wheel. They balance up to zero that way & I get no shimmy. :icon_thumby:
when my rangers done ill have to run holy cross with ya thumper113 lol if ya want too lol. as a matter of fact ill be heading down your way tomorrow for a winch for my ranger
Damn do I want to come out there and go wheeling with you guys. Actually I would love to move out there! I absolutely love colorado.
Always like seeing wheelin pics with good views and I have seen much of this in the past from you.
Nice pics. I also concur on the above stated about your truck.
AAAWWWW, don't let him kid you, Thumper is a sissy..always afraid to turn the hubs in and doing everything in 2WD.......GROW A SET MAN!!!!!!!!!!!
(J/K).................:taunt:
d35?
burly looking trail truck how do you keep that d35 together?what prob's have you had and any good fixs or ideas for someone thinking about doing an sas because of reliability problems on trail.ive got a manual tranny and lead foot maybe the d35 isent for me.
its not for you because you don't have it tuned right. I'd take 4x4Junkie's or Will's or thumper's tuned D35 over an sas ranger anyday
how do you tune ttb so bearings dont fail other than keeping the beams level and clearancing the yolks? my truck flexs great and handles good.im talking about reliability,not springs and shocks.by the way you are probably right about the rad. bushings,i had an old rambler that clunked hitting the brakes and when letting off/starting again.ive had radius bushings get crushed but i took care of it before the wheel started clunking around.anyway i was asking about problems hes had. try not to follow me around the forum when i ask other people questions eh?:idiot:
how do you tune ttb so bearings dont fail?
read the tech library. I have never had a bearing failure in a D35.
Well, aren't you a little self centered to think i have noting better to do than "follow" you around the forum.
When I log in I click the new post link and read then post, click the newpost link and repeat....... i don't follow anybody around the forum.
sorry probably didnt need to say that but the question was for him and ive had the roller bearing in the back of the spindle fail and chew up the stub shaft. ive also had to replace them on customers rbv's. also you didnt say what tuning has to do with my question
tuning tips
id like to hear any tuning tips you have,im trying to get peoples experiences not have them say you shouldnt use ttb because you dont know how to tune it tune it.-thumper sorry for the drama on your thread
I didn't tell you not to use it. I was agreeing with you that you thought it wasn't for you. D35 is not for everybody and if you are already using the stronger joints and clearanced everything and you are still breaking stuff then something else is wrong. I have seen a locked D35 stand up to 347 stroker/NV4500 with 4.56's and 35's and it didn't have near the work into it that Junkie's has. Again I will tell you to check out the tech library, all the collective TTB secrets are there.
When I just wheel it As easy as I can.......As fast as necessary, it holds together. I broke two axles in all the time I've wheeled it but both times were due to me Hot-Dogging it. After I broke the center joint, I ground some of it off for clearance............it was at a sharp angle when the passenger side tire was off the ground & the suspension was at full droop. You're lead foot will bring D35 axles to a quick & certain death. You might wanna consider changing your wheeling habit about the lead foot (since it's not really necessary on the trail) or definetly perform an SAS with a strong diff...........but those aren't cheap to build up either.
On the wheel bearings, I'm what's considered Anal about them. I never had one fail me, even after driving through creeks & rivers. I clean & grease them with a semi-synthetic grease & tighten them properly. Honestly, it's about every 4 months that I service them. Unless & went wheeling in a place that had axle high water, (ie, rivers, creeks) then I service them after I get home or the next day. That might be too often for some folks to service them but then I'm one of the rare individuals here that has never has a D35 wheel bearing failure & I run 10" wide wheels & large tires. So in my book, that makes it worth the effort.
