I got my ranger repainted 3 years ago and a trouble spot is the very lower rocker panel lip of the cab. Lots of salt, rocks and dirt managed to work themselves in between the metal and the original factory paint job which is now, I'm noticing, starting to make the paint chip off, exposing surface rusted sheet metal.
I have POR, but don't want to use it on exposed panels(UV rays mess with it over time), but when I sand the rust off, would self etching primer be best or could regular Krylon primer be used?
Also, I have the paint color for the paint job. Should I repaint and reclear the areas, or would an undercoating be better?
It's so low that no one will see it unless they get on their knees to look.
Any advice would be greatly appreciated!!! Thank You.
