- Sep 14, 2009
- Michigan
- Automatic
Skyjacker's coils are probably the flexiest of any that are made specifically for our trucks, but IMO they are still a bit stiff for some uses. I wound up instead using a set of their Jeep Cherokee coils on my BII.
I would certainly get the Skyjacker kit and see how it does for you (be sure to get the extra drop (#FA600) pitman arm with it too though). This way you'll already have a lifted foundation made of good quality components if you discover you want to try a swap to different coils afterward (and possibly shocks with extended mounts).
BTW, you can get the Skyjacker kits right here too
http://www.trsfabandoffroad.com/products/skyjacker-b2.htm
I assume the pitman arm with the kit would work fine though correct ?
