-=SOLVED=- Ignition Switch Struggles - Need Stronger Hands!
Mr. Sharkey
Minerva, Oregon
2005 XLT 4x4
New truck to me, first issue to get fixed is repairing the ignition switch.
Truck was unused for about three years, stored outside. No water incursion to the interior, but the ignition switch is so difficult to turn that it requires both hands to hit the starter. After the engine starts, the key has to be forcefully turned back to "run" position, it doesn't return on the spring. My arthritis ins't going to put up with this on a daily basis.
The key doesn't seem to be binding in the lock, steering wheel locking mechanism seems to be free, it's like the lock cylinder is binding in the casting.
So far, all I've tried is a squirt of WD40 down the keyway, which did nothing but leave a stain in my pocket.
More after I shred up the steering column trim and see what's inside. Someone please tell me that there's a simple lock nut tension adjuster somewhere....
can you just replace it?
Possibly. Just got the truck yesterday, so I'm not very far into things yet.
Went through ten pages of search results here. Apparently, there is a little rack-and-pinion setup inside the steering column that might be gummed up and need lubrication. The scary part is, that the ignition switch cylinder is made of flimsy pot metal, and has to transfer all the torque of twisting to the pinion through a shaft or tang that can shear off, making a big problem that requires dynamite to correct (well, maybe just a drill and slide hammer, but who need more work?)
Wondering how deep into the column this part is?
Now I'm thinking I'll stop cranking on the key until I get this figured out, I'm trying to fix things once, not fix them until they are more broken.
Advice for steering column/ignition switch disassembly welcome, as well any other useful tips.
Got this fixed, after going down a maze or two and finding dead ends.
First, this topic thread was very helpful in giving me an idea what I was going to find when I began tearing the steering column apart. It describes a different year and model Ford truck with a tilt wheel, but the basic layout of the ignition switch and related parts is very close. Pay attention to the part where they tell you how to be safe working with the airbag!
After pulling off the plastic panel under the steering wheel, the plastic cover from the bottom of the column at the wheel, and the trim bezel from around the instrument cluster, it was time to yank out what I'm going to call the "knee bar", a stamped sheet steel plate that encloses the area above the foot well. "Knee bar", because that's that your knees are going to slam into in a front end collision!
Once this was off, the actual ignition switch, the part with the wires that do the work, was exposed. It comes off with two Torx cap screws. The action seemed kind of stiff to me, so I drilled out the aluminum rivets holding it together and opened it up. Nothing wrong inside, adequate yellow grease and nothing binding, so I smeared any blobs of grease around and reassembled it using 4-40 machine screws and nuts.
With the switch off, I was able to turn the ignition key with one hand, but it was still pretty stiff. Jiggling it, I could see that the first section of the plastic rods was freely moving. (who designs this stuff with plastic parts, anyway?) The second rod, the front-most one that actually moves the above switch, was not sliding easily. It looked like I was going to have to pull the steering wheel and get at this stuff to find out why.
Removed the airbag, removed the Torx-head cap bolt in the center of the wheel, and went at it with a good Proto gear puller. No dice, even at an uncomfortable level of cranking and some tapping with a hammer, the wheel wasn't moving.
Figured I didn't have much to lose at this point, I put a piece of cardboard and lots of rags covering the carpet, and began saturating the front rod with WD40 (what I had on hand). Most of it just poured out the bottom of the column, where the ignition switch would be attached, but the rod did loosen up some. Temporarily reinstalling the ignition switch revealed that it worked acceptably, and even sprang back to "run" from the "start" position without help. I decided I had a winner, enough so that I would reassemble and work on something more important.
Getting the top trim cover off the steering column was not easy, and I had taken the instrument cluster loose to gain some working room, but just pushed it up instead of removing it. Now I decided to pull the cluster and polish the clear cover while I had it loose.
Revelation! First, there was evidence of a mouse getting in that area. Second, it seemed that the area had been wet at some time, rusted fasteners, dirty puddle marks, corrosion on the cast aluminum column casting. While cleaning up, something caught my eye. There was an access cover on the top of column that when removed, exposed the top of the plastic rod that I had been trying to free up!
The red circle is above the joint between the first and second rod. I had already sprayed that pretty thoroughly. The green circle is the cover that was hidden under the cluster. It exposes the front rod. The black arrow is pointing at a tab that can be used to pull the cover off the column. There's a plastic pin holding it to the casting on the left, be sure to shove it over to the left while lifting to avoid breaking it off.
Here, I opted to use silicone spray in sparing amounts. the rod can be worked back and forth with the key, exposing the top at each end. The sides are also more open and lubricant can be directed there also. After a few squirts, the grease on the rod became softer and more liquid, and the action while turning the ignition key got ~much~ easier!
Anyway, if your ignition actuator roads aren't broken, but are causing a lot of stiffness, it might be worth trying some lubricant. I wish I had known about this little hatch in the top of the column in the beginning.
Glad you got it figured out...
Thanks for sharing the fix!
heck of a write up and great pic supporting what you did.
I just joined the Forum and the first quick search turned up your thread. WOW, dead on target. My switch is intermittently hitting the wall before making contact and it always happens when I have stalled in the middle of an intersection. I wonder how it knows...... I have been thinking a torque amplifier lever of some sort might help but afraid it might break something.
I havent tried the fix yet but will tomorrow.. I am sure it will work because the symptoms are a perfect match to mine.
Thank you!!!!!
I am not quite sure what I am looking at in your picture but I havent taken the housing apart. Is the access panel accessible without removing all the other stuff? If you have a picture further back so I can see the surroundings to orient myself, it would be very helpful
Thats the top of the steering column and where the gauges would go
From the driver seat
