SOLVED: 1990 Bii 2.9 FAILED CA SMOG!
Well it's been 11 days and I need to update this thread to keep everyone that may be interested informed with what little info I have to offer at this exact time.
I replaced my catalytic converter with the Walker 80690 Calfit CARB Cat. It DID NOT bolt right up(as advertised) as you are instructed to cut a half inch off the Y-pipe. The part you cut is obviously the 2 in or so extension that protrudes into the cat from the pipe post-flange.
I premeasured the new cats mating internal surface and ended up cutting 1 inch off the y pipe end for a snug fit that fully sealed.
After this, the cat mounted perfectly with brand new gaskets and bolts(reason I risked the 80690 in the first place was due to the gaskets being exactly the same).
The bolts I used were 10mm x 50mm coarse thread as this model converter does not have pre-welded/mounted carriage bolts. This was not an issue and is truly the only difference I notice between the CAT models and why this is only suggested for a 4.0L ranger and explorer when the Magnaflow CARB covers them ALL.
I also, replaced my vapor canister that was absolutely FULL of crap, dust, spider webs, and devils soot.
Now all I have to do is fix the rear brakes and go SMOG her which I am pretty certain she will sail through(otherwise my next post will be a sadface).
Further info:
The post 10/89 1990 Bronco II does not have a Vapor Purge Solenoid between the throttle body and vapor canister. It is not included physically nor in the vaccum diagram under the hood.
Just wanted to update the thread since I haven't been able to work on the Bii until recently due to tree work and fires. BUT I installed the Walker Exhaust CalCat Carb 80690 Direct Fit and PASSED SMOG with flying colors! That Walker is a perfect fit even though it claims otherwise for compatibility. And it passed better than any newer vehicle I've ever slogged. Now to figure out these darn brakes and then she is fully functional mechanically speaking. Interior and exterior will have to wait
Thank you for the update. Glad to hear its solved.
That is great, it would be interesting to know what your MPG averages after two months. With the 2.9L I used to average 15 MPG up to 21 with my 5 speed.
