Bryotch
- Jul 30, 2014
- Automatic
Ok so I've had this issue a while but haven't bothered with it since it's been warm. All winter long my truck had problems starting. As soon as it warmed up I didn't seem to have any issues EXCEPT, when it's cloudy or rainy and less than 75 degrees or so. Fuel pressure is good, turns over fine. and even tries to fire once in a while. One thing I've noticed is 80% of the time it does this it smells like its flooded. The only things I haven't really checked (mostly cause I'm not sure how) are the crankshaft sensor and ECM. I've looked over alot of forums and my chilton's didn't help alot. Any help is appreciated. Also, I posted this under urgent because it's starting to cause problems getting to work and appointments on time.
PS Is there any way to test the relay to the ECM?
I pulled the IAT to take a look. Unable to get a good test. Worth replacing?
94 Ranger XLT 3L V6 4x4
