So what should be included here?
Bill G
20+ Year Member
Boosted (Not Stock)
A $20 fuel surcharge from Tucson
1984
Posted by Dave R:
I see that we are now open to any engine running forced induction. So here are the ones that I know about..
People whom have running vehicles..(in no particular order)
Dave R ('92 2.3 turbo)
JuBean ('94 2.3 turbo)
George ('92 2.3 turbo)
C.Marshall ('86 2.3 turbo 4x4)
TurborangerSVO ('87 2.3 turbo 4x4)
Sam8902 ('96 2.3 turbo)
Anupaum ('93 2.3 supercharged Eaton)
Hurricane ('93 3.0 supercharged Eaton)
Rock City Prerunner ('95 2.3 turbo 4x4)
neongreen ('88 2.3 turbo)
Attichus ('99, 2.3 turbo)
turboparton ('98 2.5 turbo)
rhett944 ('94, 2.3 turbo)
Chuck W ('87, 2.3 turbo)
hybridkyle ('91 2.3 turbo)
Turbo-T (84 4x4 turbo)
Bill G ('92 2.3 turbo)
Skyy_4life (94 2.3 turbo)
Sevensecondsuv (90 2.3 turbo)
tim98 (98 2.3 turbo)
ttficeohranger (91 5.0 twin turbo)
DCinDC (1993 Ranger 2.3 turbo long bed reg cab)
DCinDC (1988 Ranger GT shortbed with a rear mount turbo on the stock 2.9)
Bent Bolt (4.0 SOHC with Banshee Supercharger kit. M90 )
Scotts90Ranger (90 Ranger 2.3 Turbo)
farfromsane (89 2.3 turbo)
rpcaster (2002 Ford Ranger XLT 4.0L SOHC M90 Banshee Supercharger)
People who are currently collecting parts or actively building..
DERANGED ('95 2.3 turbo)
TexasRanger ('96 2.3 turbo)
PlausibLburn ('94, 2.3 turbo)
Outlaw ('87, 2.3 turbo 4x4)
84longbed ('84, V8 (331) supercharged B+M)
longbedGTs ('87, 2.3 turbo)
briansz - (83 2WD longbed, '87 TC 2.3t, M50D)
turboL (99 3.0 supercharged)
92dangerranger (92 2.3 turbo)
red85 (94 2.3 turbo)
07_Ranger (07 2.3 turbo)
If I left you off, please, let me know and I'll add you where appropriate.
Anybody with more ideas of what should be included here?
Posted by lowflyn:
If anyone is looking for basic writeup on nitrous a guy on my stang site made a really good one.
It's based on running nitrous on a Mustang V6, but the theory is the same.
Here's the link:
http://www.mustangevolution.com/articles/20077/
Getting around to updating stuff. If you are not on the list and want to be added, either drop me a PM or post up here.
2002 Ford Ranger XLT Supercab 4x2, 4.0L SOHC V6 Engine with: M90 Eaton Supercharger from 3.8 supercoupe-(Banshee Supercharger, Inc), K & N Filter, Xcalibrator-2, Super 40 Flowmaster, Innovate LM-1
4.0 SOHC with Banshee Supercharger kit. ( M90 ) Is installed and running.
I have my 2.3T up and running, well it was until it crapped out (starter is on the fritz and I think my ignition module did too)
One thing I would like to add is THIS wiring stuff, it's what helped me get mine going...
89 ranger
My 89 reg cab longbed 5spd turbo is running 18 psi tuned with sct by local shop. Performance Evolution! Delawares ford tuning enthusiasts!
HERE'S a link to help with adding DIS to a TFI harness
post from turboford about this
post on turboranger forums
Dave's swap thing in tech library has a pinout of wiring, helps in the swap to DIS, some of the involved pins don't exist on the '86 ECM
sevensecondsuv's wiring stuff also from the tech library, includes several wiring diagrams for comparison as well as side by side excel sheets for a couple years.
I've had to look for these a few times, wanted to put them in the sticky... this is virtually everything I needed wiring wise to get through my swap...
Since I added my wiring info for the DIS mod, I thought I'd add in the instructions for modifying the block to accept the crank sensor:
I don't have any pictures of when I did this, but its pretty self explanitory once you get the front covers off of both engines, there are 3 holes that mount the crank sensor mount to the block on the early DIS engine, two threaded and one dowel pin, they are 6mm threads and a 6mm dowel pin, you probably won't find one though, what I did was take a 6mm bolt with a long shank and cut it off so the shank was about the length of the dowel in the original engine and just threaded the hole and red loctited it in place.
to make your template, get a piece of thin cardboard like from a cereal box or something, cut it out in a relative shape to fit in the area needed, you want to use the outer bolt holes for the cover for reference points so make it big enough to get to those. Start with the hole for the pin, cut it out in the cardboard first, then take a STRONG pin or something and stab it into the holes you want to use for reference one at a time, after you stab the hole in the cardboard cut out the excess so that the correct bolt will fit through then put it back on the engine with the bolt threaded in the hole, this will help in accuracy, Start this process with the outer most cover bolt holes (I would do 3 of the cover holes for good measure, you don't have to do all of them) and then do the other two holes that need to be drilled and tapped. when you get to the new engine, take a scribe or something to scratch the metal or a sharpie and mark the holes that need to be drilled and tapped, take a center punch and mark the center as close as you can, then drill a small pilot hole like 1/16" or something then drill the correct size hole for the tap ( I believe it's 3/16" for a 6mm). at least one of the holes goes all the way through to the crank case so you will want to be careful, with the front cover off you can catch all of the chips without a problem just use some loctite or thread sealant on the bolts when you put it on. That should cover that part.
you have to use the crank pulley from the donor DIS engine, it'll swap right over. Once you get the sensor mounted and the crank pulley in place check the crank sensor alignment, take the pulley part of the pulley off (4 bolts with 10mm heads) and rotate the engine, there are some points where you can see both vanes entering the sensor, just make sure they are close to centered (I used 3 thicknesses of a business card which put it in the middle), when I used this method I didn't have to align the sensor after the swap it started right up, but it doesn't hurt to check.
one note on the front cover is you will have to notch one of the holes on the cover so that it will go on as the bolt is only about 3/8" off, the rest will line up.
Mine has been turbo powered since September '08, but it's nothing special compared to the extensive work that the other fellows have done here.
Add me just for the hell of it. My sig says it all.
Edit: Just in case I change my sig, here is the one I'm talking about. '94-XLT-2.3T-T5-8.8"-Longbed-TURBO!
i am currently un the part collecting process. going for a Folvo 2.3 turbo.
i got a 93 ranger splash 2.3 with a schitzer turbo running 20lbs with a W.R mega squirt
95 2x4 (Longbox i think)
2.3T on the stand waiting for me to find time to swap in
and then collecting parts for the twin charge setup
(if it wasnt for me having to do 2 mnths of school with my income tax, id have em already.. *pout*)
Tominator, ('95 5.0 V1 Vortech)
Running.
