Curious Hound
I know a guy with a website
TRS Event Staff
⭐Supporting Member
💻 TRS Socials
TRS 25th Anniversary
GMRS Radio License
- Feb 7, 2016
- Age
- 61
- Wellford, SC
- State - Country
- SC - USA
- Other
- 2002 F250, 2022 KLR 650
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 3.0 V6
- Total Lift
- 6"
- Tire Size
- 35"
- My credo
That is the max pressure the tire is rated for at the maximum load the tire is rated to carry. The vehicle manufacturer gives you pressure recommendation based on the load your vehicle will put on the tire. Max pressure as recommended by Ford would be the pressure you use when your vehicle is loaded to itself maximum weight. When traveling empty or lightly loaded, you would use even less. You will find the ride much more comfortable.It says 50 psi on the actual tire.
