when you would let the car run in neutral had a loud grinding noise, and the car didn't motivate in any gears, got the transmission out and i can turn the input shaft by hand and there is no response from the gears, anyone got any ideas as to what this indicates?
ALSO:
the truck is a 2.3L 4cy 4x4, m5od trans, the avaliblity of the transmissionn is slim around here, im wondering if i can use a m5od trans from a 3.0L or another engine and bolt it up to the 2.3L... if anyone knows of a swap that will open up my options to something more common PLEASE!!!! let me know.
and i guess my next question would be... if this is not possible, what adapters can i get that will allow me to use other transmissions, and what those transmissions could be, that would allow me not to spend an arm and a leg on a rebuilt trans, if this is even realistic (without shortning/extending the driveshafts etc)
ALSO:
