Mark_88
- Aug 11, 2007
- Age
- 69
- Ontario, Canada
- Automatic
- My credo
- Love Thy Neighbor
for the vacuum and fuel pressure (bonus...two in one). So the fuel pump is pushing 7+ PSI like it should be....almost bought another fuel pump without testing it...would have had a spare anyways...
Then I tested the vacuum on the intake...seems to be fine when I close the choke butterfly and stays around 20 where it should be...once I open the choke I can barely keep it running and the vacuum drops off to almost nothing...the information with the tester says that if this happens the carb needs adjustment...also that the timing is off...but the truck actually runs well with the choke closed...so I doubt it's the timing.
I've tried all the adjusting I can do with the carb in various combinations of lean/rich and idle positions...so I'm pretty sure the carb is poooched...or, as we say in French, PHuked.
If anyone has any other suggestions before I start searching around for another carb I'd appreciate it...
TIA
TIA
