CK3
I know there's a lot of rim options out there for the B2.. I just want to buy a new set of cheap wheels & here's what I'm thinking.
I would like to run this tire & wheel set-up on my '89 B2 4x4 with a 4" Rough Country lift, Bushwacker Cutouts & stock D28 & 7.5 rear.
Cragar Soft 8 Wheels
Wheel Diameter 15 in.
Wheel Width (in) 8.00 in.
Backspacing (in) 4.000 in.
Offset (mm) -13.00mm
Center Bore Diameter (in) 3.300 in.
Tires will be a 33x12.5x15
With that said... Anyone see any issues with this setup as a street driven vehicle? Are the tires too wide? The offset correct? I'm thinking of the 4" offset due to the Bushwacker cutouts that I have. I don't want the wheel sucked in the wells with those huge flares. So... What changes would you make (if any) to the above wheel & tire size??
Thanks,
Bear
Thanks,
Bear
