I showed you my truck in the other forum. I took that blade off of a '64 CJ. It was mounted to the frame and ran under the front leafs--won't work on a TTB and I didn't want it hanging down because I use this truck to wheel and go through the woods over fallen trees and such. So I made a mount:
and it's high up--just pull the pins and drop it--no frame. Worked real well as you see it until I put a corner of the blade into a culvert and twisted the hell out of it. It's 3/8" angle and I couldn't bend it out so I cut it apart and added another 50# of steel--boxing it all in and gusseting it. Then the next time I hit it hard it bent the 4" x 1/4" angle that it mounts to the frame with--but that bend forced it against the frame of the truck and it can't bend anymore. I also have a piece of chain with hooks as a limiter so it doesn't jerk on the winch clutch--and that I hold it up while I'm driving on the road. With the loose coils I have on this truck I had to bag the coils with Airlift 1000's. It's rock solid on the road now and I just pop the cores out when I take it up in the woods or offroading. I live on a steep hillside and you don't want a stiff front when you are picking your way across the slope over fallen stuff--so it's nice to be able to go from super stiff to super floppy in a few seconds.
Only thing I can say about plowing with a RBV and this heavy of a plow is--check your lug nuts regularly. I had a wheel come loose on the road once and then full off another time after doing a lot of plowing--something that has never happened to me before--and I have always torqued wheels with a torque wrench so I don't break the lugs.
I would much prefer an auto for this. I do my neighbors drive and it is long (quarter-mile) and steep enough that you have to shift twice going up it. My feet are always wet and the clutch pedal surface has long worn smooth so I've gotten my foot tangled in there when it slid off while slapping through the gears up that drive. Also, in the church parking lot when you are doing endless back and forths it would be nice to just click it a couple times and not have to mess with the clutch and balky Ford shifter--first and reverse are pretty far apart--plus you have the remote in your hand and between steering and shifting it gets wound around everything. Rather have an auto.
The B2 is almost 50/50 balanced so it doesn't need weight in the back at all. I like the short wheelbase too--same as a Jeep but a lot more weight. The 4.0 has lots of the guts you need and even with a stick its very easy to get it moving without stalling it.
All that said, I'm putting a snow blade on my skid loader and retiring the B2 from plow duties next year. I'm not going to do the church anymore--the only asphault I do really-- and I'll use the Bobcat for whatever else I do. The B2 is kind of hard on gravel driveways--I would prefer something with a little more precicion and that is narrower than the drive so I can do one side at a time. Gravel drives always have a crown and the blade pushes all the gravel off. Plus I have a lot beter vision with the Bobcat and can be a lot more careful.
