Macneilrider87
- Mar 24, 2010
- Automatic
ok guys so I have been working on my truck now for alittle bit I had a burned valve on cylinder 6. well today I finished putting everything together and it was ready. when I turned the key it started up right away, sounded good, had oil pressure and everything seemed well. well when I shut it off I noticed some smoking in the engine bay looked like it was coming from back of the upper intake down near the camshaft position sensor? not 100% sure though because it didn't last long. is this normal from all the new gaskets and what not or is something wrong? also after I shut it off there was some sort of tapping noise I heard about 4 or 5 times then stopped. any help is appreciated thanks.
