slipping trans
clinton
kentucky
i have a 89 ranger 4x4 i feel like it slipping but when u put it in 4 low it dont slip is it the trans or transfer going bad
Sounds like the trans. Try some Lucas Trans treatment,it works wonders and is ALOT cheaper than a new trans.
Clinton, I aggree. It sounds like your trans is slipping. When you shift into 4 low it becomes easier for the trans to to turn the tires because of the gear reduction in the transfer case. Lucas trans fix is great stuff. I also recomend adjusting both bands as outlined in the tech section. Search "A4LD band adjustment" for detailed instructions. Let us know what you find. Good luck!
Sounds like it's time for a 5-speed.
