Ever since I'd done the work to my 3.0 I've heard a slight static that sounds like ignition in my speakers. This only occurs when my radio is on. If I play CD's or my Ipod it'll go away. The engine had always had a miss....but I figured the exhaust leaks before the HO2S's, bad plugs, and worn cap, wires, and rotor had something to do with it. Now all of that is gone. The only igntion items I haven't messed with are the module, coil, and (little cylindrical silver thing mounted on the bracket next to the coil. It has one wire leading to it, and I think it's called a condensor???). I'm going to try and diagnos by going through the chiltons tests with my DMM.
I wanted to hear if others with 3.0's or 2.9's had the same issue with their distributor ignition systems.
