Sliding rear window seal
2008f450
Loveland,CO
Hello all. I have a 93 standard cab Ranger . It has a solid glass rear window. I picked up a sliding rear window from the u pick it the other day but now I need to find a new seal to put it in with. The slider came out of a 94 and it is a Carlite so should be easy. I just dont know where to find a seal. Rock auto only has the seal to install flat solid glass. Thank you all
I haven't had any luck locating one of those seals either. If I find anything, I'll be sure to share it here.
Are they different? When I swapped my solid glass for a sliding window from a junk yard, the seals looked identical.
I found one at LMC for $129.00 OUCH. They say its for a slider but it looks like the same one I used to reinstall my flat glass when I had it out. Will let you know how it goes
on my 94 it slider is bolted and sealed with urethane
