slick road bent my spindle!
bcost882
U.S. Military - Active
The Queens Country.....
Well my truck decided to go straight when i wanted to turn so i hit a concrete barrier while the wheels were turned. I took everything off and it looks like the spindle shaft is tweaked down. I don't know if anyone can help me but i don't know who made my spindles but it looks like i can replace the shaft if anyone can help much appreciated.
this is how it attaches
just so i can start looking for part numbers or call the company
i would say a four wheel drive supplier. not sure where Nellis AFB is. try four wheel & off road should be easy to find number and call them you might need to send them pics. or you might try ?????? auto store see if they carry spindles only then have yours pressed out and the new one pressed in. Good Luck.
I know with some of the higher end spindlas like on the camburg 5.5 kits, you can press the spindle spuds out.
search around on dezertrangers.com bet you will find the info your looing for.......try the search "spud" and see what comes up....
