rossi.parridisio
- Mar 14, 2016
Hey guys, I just recently replaced the slave cylinder in my 94 4.0 liter ranger. After mounting the transmission back in, I refilled the transmission fluid and began to bleed out the the slave cylinder. However, no fluid came out. I checked the clutch fluid level and it seems fine. I pressed the clutch pedal and had no resistance at all. It returned back to the normal upright position after I let the pedal go. With the car off, I tried moving the stick and it is stuck in neutral and will not shift into any gears even if I try using the clutch pedal. I tried starting the truck, but it wouldn't start and now the clutch pedal will not depress. Not sure what is going on.
