Slave cylinder issues
FLATBLACK92
hey guys, jus picked up a 92 ranger xlt, short bed, single cab, 5 spd, but tranny is out of a 94-95 ranger which according to tech library on here runs the same tranny until like 2001. its a 2.3l 5 spd. i got a nasty slave cylinder leak, now, the feed line, going from the master cylinder to the slave cylinder, is there supposed to be a plastic cap that snaps into tranny with that line feeding thru it? ill post pics but dude that owned my truck before i bought it looks like he shot stucko up into the tranny to keep the line in place and i guess there is a crush pin that secures the line to the slave cylinder???? is this correct? my intentions are to pull tranny, replace throw out bearing and slave cylinder, im jus wondering if im missing parts???? the truck is a POS
ok how do i add pics from my computer onto this thread too???
also, anybody know where to pick up a slave cylinder hose? the one that goes from master cylinder to slave cylinder???
The hydraulic lines are best changed when installing the master cylinder so you can bench bleed it. I suggest doing both at once because I dont know if you can get it to bleed right when you replace the line. Best to get the complete combo from rock auto or napa.
awesome thanks guys, i got a hose for a 88-91 but nothing can be bought for a 92 or newer except a 01 and up, anybody know if the master cylinder from a 91 is compatible on a 92? got the hose for a 88-91 but the fitting going to the slave cylinder is way different
I " think" Ford did away with the quick disconnect on the replacement hoses.
I could be wrong though.
