Skyjacker Sway Bar End Link Question
du510
Stuck between NYC & Boston
So I've got 6" of suspension lift in front, so I figure I ought to get some longer sway bar end links. Naturally, I went with Skyjacker (Part # SBE734-L).
I got them today, no worries.... but I put it side by side with the stockers, and its only about an inch or two longer? I was expecting some serious difference in length.
I went on the SJ site to doublecheck, and I did get the right part, they describe it as follows:
Part Number SBE734
Description
Sway Bar Extended End Links; Front; Lift Height 5 in. - 6 in.;
Is there something I am missing here? When going from a stock height to 6" taller, why are the end links only 1-2 inches longer???
Thanks in advance.
I got the set that came with my 4" lift kit (234RHKS-A) and they're the same size as the stock ones. Go figure.
If you want a laugh....try and fit them into the stock locations on the axle housings. They're too wide, gotta modify something! :icon_welder:
If you have the skyjacker coils in there, you're not going to need the sway bar anyways.
