wayfast73
- Mar 9, 2011
Im rebuilding the 3.0 out of my 2000 since it blew a rod. while taking the engine apart I noticed when the previous owner put the heads on he had the head gaskets reversed (passenger side had the left gasket, drivers side had the right). I also noticed at the front and rear on the block on both sides was big oval coolant passage, which on the felpro gasket only one was open on each side. I believe their both supposto be open? If so that would explain the truck getting so hot, but I also know theres a gasket difference on for the front wheel drive 3.0's and I wasnt sure if it was a universal gasket used for both. I know the head bolts need to be replaced whenever you take them out, but has anyone reused them with out issues? Its just a 3.0, I dont want to be dumping a ton of money into it.
