Side Marker Light
JULIUS
St.louis
I asked before and was told to remove the head light and not the assembly but it looks like I need to remove the entire headlight assembly to access the side marked bulb.Is there anyone out there who can talk me thru the procedure. Thanks !!
pull up on the tabs that secure the headlamp, wiggle the headlamp out, while i'ts half way out, undo the signal bulb and the headlamp bulb connectors or just take the bulbs off the housing. set housing on intake. lol. Then take a 7/32" socket to the corner lamp screws, pull out on the corner lamp, twist the pigtail/bulb holder lefty loosey, then pull out. pull out bulb, put in new one, install is reverse.
Look in your owners manual...it's got neat little pics to show you how to do it.
Thanks man!! I like the,"set housing on intake".LOL I guess I asked for it.I had no idea directions were in the manual. Thanks again
yupyup. no probs. by far, the easiest headlmap removal i've ever done...is on 01+ rangers.
Finally replaced the bulb and I couldn't believe how easy it was. I've never,ever had to move a headlight to replace a marker bulb.Normally I can access the bulb without bothering anything else. Thanks again for your help!!
