Short water pumps and pulleys
keithm
90 Ranger with
It appears that short water pumps were for serpentine belts,does anyone make a v belt pulley for a short pump. I was thinking a short pump with the standard v belt pulley would probably not align with the bottom crank pulley. of coaurse there is the question of rotation.
This is the second time you've posted this same subject. Did you not go back and READ the answers to this the FIRST TIME ? :buttkick:
Yes I did, but I'm not clear as to whether the short pump was used on both belt setups
Go back and read it again, I made everything perfectly clear. There was no stock application for a short std rotation pump.
