Shocks on the Shop Truck
FrankBoss
Oklahoma
First I'm totally surprised there is NOT a shock thread as a sticky or in the tech section to cover what shock will cross for a budget lift or different utility.
My Truck (2wd) with 2 inch blocks and 2 inch shackles.
the front has 2 inch spacers under the springs.
So far I have stock shocks and they are racked out. "23 inches"
I'm going on a salvage run Friday and would like to get something to help correct my miss match of parts. I don't off road but I haul and tow with the truck if that makes a difference. Gas, Coil spring assist...Just plain jane?
Do you guys have some suggestions... on the cheap.
FrankBoss
air shocks. i bought monroe air shocks and i love them and ya cant beat the price, i have way overloaded the rating for loading for box and the tires didnt go in the fenders like before i installed the shocks. installiation is easy run (everything is supplied) n air up r air down
I haven't had good luck with air shocks. I wished I did...
my current shocks are 23 inches full extended..and racked out with 2 inch lift. I added 4 inch of lift to the rear so a 27 inch shock would be racked?
I'm leaning toward a adjustable shock with the spring on it.
Frank
I found a part number for a Ford F250 shock that measures 17.5 compressed 30 extended.
Monroe 557001 but I'm afraid its a Front shock. I need rears.
The Sensa-Trac load adjustable is what I was thinking but there is not much for cross referencing parts.
I'm still looking
FrankBoss
