trademarked67
- Mar 16, 2008
I am the original owner of a 94 Ranger 5 speed manual transmission with 193,000 miles. 4 cylinder, 2.3 L engine. Never had any mechanical problems with the vehicle, clutch, master and slave cylinders are all original. Two years ago there was a four or five week period in the early spring where it was difficult to shift, especially trying to put it into first gear. I never got around to doing anything about the problem before it went away. The following year during the same time of year, the same thing happened for about a month, and then it stopped.
This year, same thing started about 2 weeks ago. Driving home last week, I was having a terrible time getting it into first gear, then when I did get it in, the truck jumped forward like I had quickly dropped the clutch. Barely got it home before it got to the point where I couldn't shift it at all while it is running. When the truck is off, it shifts easily through all the gears. When I start it with the truck in gear, the truck wants to move forward while the clutch is engaged and there is a loud clicking noise.
The clutch reservoir is full and there is no sign of leaks from the master or slave cylinder, but I did bleed the hydraulic system and there was no change. The transmission fluid is at the proper level also.
Before I drop the tranny and replace the clutch and slave, I would like to know if there is something else I should look. Also, I will be working on this by myself and don't have jack to lift the tranny - is this doable and do you have any advice?
