Shifting into gears
rypp77
Houston
I have a 1996 Ranger / 2.3: I have been trying to fix a problem that is taking me is so many directions. I replaced the Slave, Master, TransLine, Pressure Plate, Clutch, Flywheel, Shifter bushings. I still can't get it to engage into gear when its running. Now, right after I replaced the shifter bushings, I can't it even get it into any gear. Before, I could get it into any gear while the truck was off, not I can't even do that. I was thinking it was the master or slave that had air in the lines but now I'm thinking its the transmissions. What kinda advice can you give me or test to figure this out. Oh help me wise one.
- Ray
sounds like the pilot bearing to me
Most likely air in the system, they are a royal bitch to bleed.
