Talus
Ive been caroosing around this site for a while, and have found many answers to my questions just by using search. I have found something that I cant fix myself!
I have a 1993 Ford Ranger, 2.3l engine, 2WD, M5OD-R1 trans.
My problem:
I took out the four screws which fastens the rubber boot to the top of the trans in the cab. I then used a T35 bit to pull off the three screws which fastens the stick into the trans, and set the stick aside. Looking at the top of the trans, there are two pins on the left and right sides which keeps the stick from swivelling in either direction. One is broken like a chipped tooth, the other is worn down and has issues sitting in the hole. Because of this, I can not really get into first or fifth gears. Reverse is an issue, but I can manage to get it in there without having to apply brute force.
Potential solutions:
Going to any nearby junkyard for these two pins are ruled out. The ones that do have a Ranger, the trans is gone already. One yard told me that I cant just pull out the pins without taking the whole trans, and I asked if I could get a bracket instead, and they just kind of shooed me on. (Lucky for them, I would have tapped these pins out in a heart beat)
Going to a dealer is ruled out. I went to Ford, and they printed me out an exploded view of the entire transmission. Part 7221 on the diagram, with a star next to it. They dont make that part anymore. Since its a Mazda transmission, I tried Mazda as well. No luck.
No parts store has it as far as I know.
My buddy suggested using a lathe to make them using a sort of hardened steel which could be anodized with some kind of salt. I would rather not do this, but if I must, I will.
Any other potential solutions I havent thought of, or maybe someone has a couple pins they could sell me?
Thanks in advance guys.
My problem:
