woody1963
- Oct 28, 2009
- Automatic
Hi gang. I think i got some electrical problem with my shifter linkage. maybe it's mechanical...not sure. Could use some help please. 2000 ranger xlt 4x4. 3.0 litre, auto tranny.(4r44e I'm thinking). Electric shift T-case.
Here's what happened. I parked my truck,put it in park,shut it off. Returned shortly, fired it up,applied my brakes,attempted to shift into reverse and my linkage would not allow it. I tried a few more times. no luck. But by chance
I turned the key to the on position,motor not running,applied my brakes and gave my shifter handle a good yank and it came outta park. still won't shift with the engine running but if I repeat the befor mentioned pull, i've had some luck. Got my dash apart tonight and I see a problem. My linkage actuates a cam like roller that depresses a plastic plunger on top of some electrical sensor. The ONLY way i can shift outta park now is to pull on my gear shifter slightly,toward me,then turn my ignition on,thats when the shifter comes all the way back to the position where i can select a gear. Sorry for the info overload. I'm trying to be as specific as I can. This has me confused. I put in a different 3.0 last year.The orignal spun a bearing.CPU went out when the kid was driving down the freeway.I'm starting to regret not swapping in the manual tranny,along with the engine, from the donor ranger. Any help or advice would be great. Thanks from the pacific northwest.
