Okay, finally got around to fixing my 4wd. Found the diagnostic page in the tech library and got it down to a frozen shift motor. Got a new Dorman from Advance Auto for $70 after a coupon discount, but when I got back under the truck to finish the swap realized it was missing 3 wires. After a little research on the web found that I am supposed to pull the pins out of the connector to the three wires(speed sensor and ground to case) and plug them into the connector on the new motor. The question is, how do I get the pins to come out. I had to use a magnifying glass to even see that there are tangs there, but I can't seem to get them to move so the pins will pull out the back side. What am I missing.
