Shift Boot
CurtisP87
Portland, OR
I recently pulled my shift boot out so I could put truckbed liner down in the bronco tub, and noticed the gasket was starting to wear down and the boot wasnt sealing to the floor pan properly. Ive called around stores and dealers in the Portland area and it seems the OEM boot is out of production. I could go to a scrapyard and try to find one, but I figure the odds of it lookin any better than the one I pulled out of mine are slim. So Im starting to look at an aftermarket boot, but Im worried about it fitting and accommodating the t-case shifter...I have the 5-speed and manual t-case. My question, then, is have any other users with the same shifter setup used any aftermarket boots they can verify will fit and look decent? Thanks in advance for any help!
Fairly certain I have a good stock shift boot. PM if interested.
bump. 88B2EB's boot wasnt what I needed, the question stands....
Thanks for any advice.
