ctgriffi
I've got a 2WD, 4.0, '94 XLT Ranger with about 172K on it (original motor and A4LD), and I'm getting a pretty fast, intense vibration when I reach between 60-70mph. Seems to be steadily worsening.
I jacked it up yesterday and checked out the ball joints and tie-rods on both sides, and, honestly, I can't see any unwanted movement in those joints. I did notice that my passenger-side front wheel bearing seems a hair loose, and I'm going to pull that apart this weekend to adjust/repair.
I know that driveshaft problems can cause something like this, so I took a look at that, too: I couldn't see/feel any looseness in the U-Joints, but the frame-mounted center support might be a problem. When I yank on the shaft near there, I can see about 3/16" amount of play in the rubber bushing inside of the support. Thoughts?
Also, the tires aren't in great shape either - a couple of them are pretty wonky, thanks to my RA bushings going bad, until I replaced them several months back. Still, it was driving fine for a good while after that - up until about 2 weeks ago, so I don't think this vibration is tire-related.
Thanks for the help!
