Shackle removal
BuckskinRanger
Alberta, Canada
I'm having one hell of a time trying to remove my bolts holding on my stock shackles:bawling:. BFH won't do it, air ratchet won't, starting to wreck sockets with the strong arm. Problem is I can't get the bolts through the inner sleeve. I have the differential jacked up to hold the weight. I'm gonna go back out now and remove my tires to save weight there. But I don't know if I should turn to heat cause the bushing in the leafs. :icon_confused:
Any advice will help a lot. Thanks guys.
Kyle.
If I'm thinking of the right area, try this;
Cut off the bolt head. Stack washers as needed on the other side and tighten the nut. This will pull the shank through the rusted metal sleeve.
Good luck,
Richard
I have a ball joint fork, or pickle fork I heard them called. But I can't get it behind but I could if I cut off the bolt head. Thanks Richard ill try that.
Thanks but I just said screw it because I already have an AAL in there and I never checked my pinion angle before I did it, and I dont want to mess it up with the shackle lift too. But I'll save them for my future ranger I want to buy and build. This one ill leave as is until more breaks, my rear end is on its way out I believe so when it's gone I'm putting a pair of 1963 f250 4x4 axles under it. That will be after I restore my 88, just bought a donor truck for the box and floor boards.:D
Thanks again,
Kyle.
Dunno where you get your parts, but the shackle kit from Dorman comes with a new spring bushing and both bolts. And the perch/ mount kit comes with the 4 12mm bolts for the frame.
Get the torch out. I had this fixed in 20 min.
Sent from my HTCONE using Tapatalk 2
Thanks ill look into that. But I'm up in Canada and never heard of that store. But has anyone done the belltech shackle lift with the add a leaf? I want to know if my pinion angle would be fine or not. That's what really made me stop when I was pulling the torch out.
Dorman is a manufacturer, not a store.
They redesign and improve OEM replacement parts.
