sheliable
- Dec 2, 2020
- Cincinnati
- 3.0 V6
- Automatic
Just changed the lube on my 2wd 3.73.
The old lube was yucky, but the inside didn’t look too terrible no obvious damage or metal shavings. Teeth look good.
Anyways, I still get like a whirring noise at any/all speeds and prominent when deceleration. it’s not terrible.. but I Figure it needs a new ring/pinion bearing. I have a shop that would probably do that repair for me relatively cheap for what it is.
I can’t even tell how bad it is, I mean I can hear the whirring but it’s not anywhere close to as bad as my Tahoe which absolutely whaled on acceleration whenever I drove it. Does anyone else’s diff make some whirring noise but not enough to make you super concerned? How can I be sure it’s the diff that’s making the noise..? Anything else it could be?
Should I just nut up and find a 4.10 limited slip to upgrade my rear end instead? Only thing that worries me is the MPG hit. How severe is that gonna be ?
