Seriously considering a new tow rig....input?
Sorry, I don't talk to zombies that resemble Raven's OLB Suggs.
Ive actually wondered why they switched myself. The old kingpin TIBs ive had (they used them till 80 or 82), never have any front end issues.
Ball joints have lower parts count/easier automated assembly.
King pin: Lower kingpin bearing seal, grease retainer, grease seal, cup, grease, cone, bearing cap and 4 nuts versus ball joint: Lower ball joint, snap ring, nut. 11 versus 3.
Top for ball joint adds a cotter key; for king pin, there are additional knuckle pin, spring retainer, spring, cone bushing, knuckle pin and shim(s). So 17+ versus 4.
Assembly of ball joints is simpler too – press in ball joints (2x), snap on rings (2x), insert onto axle knuckle, tighten nuts (2x), ease top nut off to allow insertion of cotter pin, send down line. I get 9 steps
There are 11 steps for lower kingpin and 16 for initial install of upper kingpin, then check of preload = 28 steps minimum. However in most case it will require: disassemble of the 4 bolts & cap, adjustment of shim pack, reassembly of cap and 4 bolts*, followed by confirmation of preload. + 12 steps. Repeat if you got it wrong.
* I can’t remember off hand, if the cap bolts need to be tightened in stages or not...
Add it that we need a more skilled person to do the preload check and evaluation of shim pack changes and for the assembly line, ball joints are the way to go.
Unit bearings have similar issues.
My personal F-100 has kingpins and spindles, not ball joints and unit bearings. But when I am designing at work, you will get the newer $hit - we have to send it on down the line. :thefinger:
Kingpins dont snap.
I hate unit bearings even worse.
Devils walk amongst us.
But wait, now they duscovered they can press everything together and not have to worry about bolting it onto the vehicle. You have to remove the knuckle, press the hub out of the bearing, press bearing out of knuckle... and then repeat in reverse for reassembly.
Did that on my wife’s edge, I haven’t replaced the wheel bearings in my ranger since 2000.
Were you not aware that Jim is PC and even allowed design engineers on the forum :) Course I don't know how to take that; is being considered devil better or worse than atheist? (i.e. engineers must be atheists - no sign of intelligent design). :icon_twisted:
p.s. I don't work for Ford, so you can relax about your Ranger, but there are a number of products that you may very well use on a regular basis that I have had my hand in design of, just to scare you.
Kingpins dont snap.
The number of ball joints which snap within warranty period is far lower than the savings from ease of manufacture and assembly over kingpin that Dana won't be going back.
And post warranty repair isn't a bad thing, if you are in the replacement parts business :thefinger:
But wait, now they discovered they can press everything together and not have to worry about bolting it onto the vehicle. You have to remove the knuckle, press the hub out of the bearing, press bearing out of knuckle... and then repeat in reverse for reassembly.
Yep, saves 3 fasteners and time to install them. Progress. :icon_rofl:
Apologies Rusty for hijacking your tow rig thread.
No worries on the hi-jack.
But ya know...i dont personally care about ease of manufacturing/assembly. I want long term, low maintence durabilty/reliabilty. Shit i can beat the hell out of day in and out, and do nothing but shoot some grease in it once every few years.
I wish engineers/designers would use that thought process. If they did i wouldnt be hanging onto my older shit like i do.
The day a semi hit me head-on was the day the music died.
I just flipped the remains of my Ranger over and salvaged the bottom parts of the Ranger. If you can service a trailer axle, you can service the front axle of an old Ranger. I've grown to like my FJ for it's crude interior and driving style, but underneath it's full of unserviceable parts, multilink suspension bits and sensors stuck in places you didn't know a truck had places. It's like an old movie redone in CGI.
My world is filled with engineers. My wife is an executive at Cummins--high horsepower, like 95 liter locomotive, ships and mining engines; my brother is a patent lawyer, and has a degree in chemical engineering; my brother in law is also a chemical engineer and has 2 other master's degrees in engineering. My father-in-law has a PhD in physics and another brother in law has a Masters in physics. Everyone I know--friends, family etc--male and female, are damn scientists or engineers. I am the stupidest person I know. And the only one of the bunch that knows how to pack bearings.
Which leads me to believe that engineers try to design stuff that people like me can't service so they can pay more to buy assembled parts to have bolted on by a monkey in coveralls.
