Redwood650
- Dec 28, 2008
- Automatic
Hello all,
05 ranger 3.0 v6 65000 miles. Just recently changed the heads as the valve seats on cyl 2 were burnt. Everything has been great, runs good, no issues, until today. Did and oil change yesterday, and also noticed the coolant reservoir looked a bit low so I added a little bit to it. Drove it to the store last night and everything was fine. Woke up this morning, went to the local DMV (closer than the store is) and when I shut the truck off, I could smell coolant. Looked down and saw it leaking. Temp gauge was normal. Took it home, pinpointed 2 leaks. First was about the right valve cover, but under the upper intake manifold. It was spraying a stream of coolant from somewhere near the intake...
The second was coming from the thermostat gasket, I first thought it was coming from the left head since that is were I first saw a leak but I traced the thermostat leak to near the heads...
Any suggestions? I took some coolant out and I am going to drive it 15 miles to work and see what it does.
