brandon1122
- Mar 2, 2009
- Automatic
Im sure this has been brought up a million times but i have a 1999 ford ranger extended cab first of all i bought the truck and it had been sitting for two months and a bit and before it was owned by a single guy who had no need to open the rear doors. Now i would like to be able to open them and they are sealed tight. Any suggestions? There is access to the bottom latches on the drivers side as there are factory drilled holes with plugs but you cant get your hand through them and on the passengers side theres only one hole. If i wanted to replace the latches i cant because i cant move the door at all... any comments or suggestion would be helpful at the moment. Thanks !
