rkneeshaw
I just bought this truck last fall and it was in shambles. I've got it running fairly good now (after new plugs, coolant temp sensor, cleaned MAF, new air filter, cleaned IAC valve, new O2's, new fuel filter, injector cleaner treatments, maybe a few other things, cant remember, its a long list). It idles great, seems to run smoothly, and no CEL.
My problem is that the motor seems to have no power above 3000 RPM. If I need to pass someone, I pass in 4th gear and at 2500 RPMs, becuase if I shift into 3rd with 3000+ RPMs, I really go nowhere.
Is that normal for the 4.0L OHV motor? Or should I be seeing more power at 3500-4000 RPM than 2500 RPM?
