stingray
- Sep 6, 2009
- Automatic
ok guys, so i have replaced heads,all new gaskets,timing chain and gears,cam sync. and crank sensor,truck runs but hard to start and misses,after starting truck this evening and looking around i noticed that both of the exhaust pipes coming off the manifold were glowing red. i will assume that the cat is clogged. will this explain the miss in engine and hard starting
