- Oct 14, 2014
- San Francisco
I've been toying with the idea of adding a second tank to my Ranger.
I've been reading a few threads about it but they're not very informative.
It seems like there was a second tank option for the Ranger at one point but it's rare to find, so a Bronco 2 tank is probably my best bet. It hangs low but my truck is already lifted 4" so it should clear.
Seems like the B2 tank fits between the frame rails just fine, but might(?) require the crossmembers out of the B2? or a custom one?
The two main issues it seems like are that the short bed Rangers have a shock mount in the way, and the filler tube points at the bed.
How bad of an idea would it be to just move the shock mount to the other side of the frame rail?
My bed has a second angled spot in the back identical to the one in the front that the filler tube goes through, this means I would have clearance right?
Most threads mention having a second fuel pump and filler neck, but why would I need that?
Couldn't I just plumb the B2 tank into my current tank and have it function as one big tank?
