seat question
'95 ranger
09/2013 STOTM Winner
MTOTM Winner
Lindale, Tx.
will buckets from an 87 bII work in my '95 ranger?
In most cases, yes...some have different mounting brackets but you can just use the ones in the Ranger...only 4 bolts to remove them...
Do you have a 60/40 bench now? If you do you might have to use the mounting brackets and drill some holes for them...
The 60/40 split bench uses the same brackets as bucket seats would in that truck, a solid bench only has one bracket on each end. If you have a solid bench now you would need brackets out of a truck with the same cab configuration as yours.
