Brain75
- Aug 8, 2024
- ~Sterling
- State - Country
- CO - USA
- Vehicle
- Ford Ranger
- 2.9 V6
- Tire Size
- 215/70R14
I've reached the point in my body work that it's time to open a tube of seam sealer... since the stuff is $20 a tube and I know that I don't know everything I thought I would ask.
Do these (2nd gen specific) Rangers have any well known failure points? Feel free to comment on other generations as I don't mind collecting all the info in one place for others.
Beyond the easily findable thread I didn't find much:
www.therangerstation.com
FWIW, the auto glass companies gobbed rubber up into the corners on mine. I bet they know this flaw and get tired of people coming back with "leaky windshields" when it is really body, just gobb a bunch of rubber on it and then it doesn't come back to them.
The 2nd gen (or at least mine) has a FULL skin on the roof - there is no access between the inner and outer skin, so you don't really know how much water has been getting in between the skins until the inner skin completely rots out.
I'm used to the old old classics which always have rust in the rear cab corners (cause they had deep pockets that hold water). So I looked around there already...
Anywhere else that is a known trouble spot I need to check?
I've already cut all the rubber out and chiseled the drip rail clean (it was cracked and couldn't possibly hold water, but no leaks reported).
1st/2nd gen Roof leak/rust prevention PSA
This definitely pertains to 1st gen owners and probably 2nd gen owners as well. In the course of doing a bunch of body work on a truck, I found a place that is probably the source of many wet headliners and roof rust. This area had seam sealer applied to it at the factory but it was cracked...
