LilBlueTruck
- Feb 24, 2008
Hey guys,
I did the front brakes a week ago on my 2000 2.5L prerunner (4x2) - new rotors, pads, hardware, etc. I cleaned everything up, regreased all the friction points, and put in a new set of Timken wheel-bearings with inner-seals. As I was finishing up, I went to put the dust-cap on that gets pressed into the hub of the rotor and it slid right in. Apparently the bore in the center of the new rotors is a bit larger than the old rotors. A little annoyed, I used a pair of pliers to bend the outer edge of the cap outward so that it would fit tightly. On the other side, the same situation occurred so I did the same thing. As I hammered the cap in, I noticed a little grease squeeze out, indicating to me that this was not a very good seal. I could go and get a new set of caps but fear that the new ones won't fit either. I do not want dirt or water getting inside the rotor, since this will contaminate the grease and destroy the wheel bearings. I was thinking of sealing the lip up with Indian-head shellac or Teflon-tape or plumber's pipe-gunk, but don't know how well this will work since there aren't any threads and the temperature of these brake-parts can get very hot. Any suggestions? Thanks for your time.
