SAS steering questions
LittleBigFoot
OTOTM Winner
Solid Axle Swap
Denver Colorado
Today I crawled under my donor truck, a 78 full size Bronco.
The P.O. put a 6" lift kit on it. When talking to him, he began to ramble about how only one side of the powersteering works and there was a problem with the pitman arm because it was stock.
It got me thinking about how I'll be running my steering when the Bronco axles are in.
I'm planning on having the box mounted inside the frame, so I don't think the stock bronco box would work. What about yotas? I've read that Yota IFS boxes bolt right up to the ranger shafts. Drop pitman arm and good to go?
Point me in the right direction
Thanks,
Adam
i would think that mounting the box out side the frame would help reduce bump steer. what other factors made you decide on putting the box inside?
i have a full width D44 and i am using my stock Gear box for my 87 B2. i have the 4-6" drop pitman. i used the steering arm from an explorer and retained the stock arm between the two tires. I do not seem to have any problems driving up to 55 mph (36" Irok Bias tires and 11" of lift total) anything over 55 is just stupid with my truck. No need to go any faster. But my gear box is pretty loose. Guess i had to many times runing it with water in it instead of PS fluid lol.
But make sure your trac bar shares as close to the same angle as the tie rod arm. Seems to handle alot better when they are close to the same angle.
space is tight on the inside of the frame, go with a yota or scout 2 box outside the frame.
id say keep your stock ranger box never put yota crap on a ford!
I'm plannin on runnin on the outside.
Yeah, and rack and pinion steering doesnt work too well for a solid axle suspension..... '
Thanks guys
Why?
On 97 and older Rangers box is inside as with most older Fords.
That's the setup we have on my buddys mud race truck. Not a lot of suspension travel needed tho.
Why?
it means that you can have a longer panhard bar which means less lateral movement as the suspension compresses, and it means that (depending on exactly how you design it) you can have a longer drag link and it should be easier to make it match the angle of the panhard.
I mounted mine back on the inside (3 different Rangers)and have no bump steer,although I am running full width.
Thanks,
Adam
Well, to answer some of this for you. The Yota IFS box will work, kindof, with the ranger shaft. If you're talking about the splines on the ranger shaft being the same as the shaft of the yota box, with one exception. The yota shaft (on the box) is completely round with splines all the way around. The Ranger shaft has a flat spot on the box, which means you will have to take a die grinder to the inside of the steering shaft coupler, and round out the flat spot. This leaves you with 1/3 of the coupler unsplined, and could result in slippage. the other option would be to grind a flat spot on the yota shaft. The pump and box (assuming you're talking power) will work together quite well, you just need to adapt the pressure line from the ford pump to the yota box. But, after overcoming these obstacles, you have a box that works great, but has the pitman arm pointing backwards instead of forwards like you need it, and if you flip the pitman arm around you would be steering backwards.
I ended up going with the box from my donor truck. A 78 Bronco. Arm on the outside, but I can use it with my pump and I still have the steering shaft from the Bronco. I can adapt that for use with my current set up to keep the steering column tilt etc.
I'm usin the stock bronco buckets and shock mounts, and the driverside shock mount doubles as a track bar mount. I'll be using that too. The angles should be the same in the end
The Mutant Pony has Rack & pinion steering and a straight axle.
