sas question
rustyballs
Dryden,Ontario
started a sas on a 93 ranger,question is which is the best c bushings to use with a 3.5 ed coil
I'd use the 7* bushings, I have them with a 7" coil and only have 2* of castor and you should be aiming for 5-7*. Average is 1 degree per inch of lift, and 3.5" coils should get you to the 6" range above stock.
I've got the 7* bushings with 3.5" coils. Just got my alignment done and found that I have 6.7* of caster.
