SAS Coil Buckets
rustyballs
Dryden,Ontario
Just completed my 93 Ranger Ext Cab SAS, I dont like the way the coils sit in the stock buckets, was considering buying 66-77 bronco buckets and changing them does anyone know if these would work or have pics, i will also be buying the shock towers to.also could someone direct me how to post pics, thanks.
Host your pics somewhere. I use www.photobucket.com because it is free and works well.
Copy/paste the image location into your post
You can click the
and paste the properties there.
i bolted them in then welded arround them., then used the shock towers off the 73-79 donor.
i have to knotch the driver side frame, (cut out a section. due to ps. pump) but these buckets are as thick if not thicker, thats why i welded them in
pm if u have questions (have a hard time keepin tabs on threads)
may have a build up on it when ever i get it finished. got the rear shaft made. just gotta put the other gears in....it was one of the .. im just gonna swap in the front and rear axles, then it turned into...Extended arms. 63'' chevys..Taurus fan, Paint, sun roof.. and on and on and on,,, long story short, has taked me about 14 months of work. usually waiting on parts, or $.
Yeah but no trying to hijack... I hope he goes the route I suggested ...idc what ne one says..eb coils do not fit in stock towers worth a sh't.... u will love how these are
4.5"cut off wheel....it's really not as thick as I think it should be... Take a little at a time and make it a tight fit
Could use some like this. I just swapped out my RBV coils for some EB coils.
Out with the Ranger coils.
Mount the retainer onto the TTB.
Bolt the EB coils in.
Took about 15 mins. per side.
