SAS axle chioce
Muddycowboy
GOT MUD?
Randolph, OH
looking at a couple D44's on craigslist found one out of a 72 bronco w/traclok,3.50 gears for $200 pics below
And another seller has one is out of (older ford truck) this one is a high pinion and comes with a 9 inch and both were sand blasted and painted but that all i know about them , no pictures for $500.
what would be a better choice, if i find out more about the second set i'll post it.thanks Adam
72 EB axle will be drum brake front. Will have to swap that to disk if you wanna run it.
The hi-pinion would be the better choice. Full width with disk brakes already. Price is kinda high unless it's been recently freshened up with seals and bearings. I priced mine at $400 and they have new seals, bearings, ball joints, and Spicer u-joints.
Mine are 79 Bronco axles. HP44 and 9. Price was for set. I gave $150 for the set and went thru them completely. Also got new calipers and wheel cylinders and Warn premium hubs.
